I have a 1997.5 gsx limited that i put a fresh topend , rebuilt the carbs 165 mains 85 pilot and dull silver spring w/ 25psi popoff beings im at sea level (originally had 145 mains 65pilots and gold spring ) . I also replaced the reeds , all of the fuel line and flushed the fuel system. I deleted the oil injection and running 32:1 ratio for breakin . It ran beautiful for the first tank cruzing around . After the first tank i replaced the plugs , rode for about 2 hours and it killed at WOT .afterwords It ran as if it was on one cylinder . I inspected the plugs with the stator cyl looking lean . I removed the exhaust and carbs and found the top exhaust side of the piston melted . Pto piston looks fine . Disassembled and checked carbs . I found no debris in the carbs , fuel line or fuel filter.
Any advice on what could have it caused to run lean before i replace the piston would be great. TIA
