Hi. I was riding in the sea the other day and there must have been a tide because there was seaweed all around the port. I have never experienced this before and I have only been riding for around 15 hours in total. I had to ride over the seaweed to get to other areas. At one point i heard a strange noise from the engine or the impeller. I eased off on the power and then the noise disappeared. About 1 hour later I went over another patch of seaweed, this time I heard the same noise but when applying more power, it started to make a loud clicking noise. I could only go a maximum of 5mph, otherwise the noise would sound even worse. I drove it back to the port, somebody checked the bottom of the ski for me and found nothing. I took it back out to sea and it was working fine. I am just wondering why this happened and if its safe to ride over seaweed on a jet ski? Can seaweed be easily sucked in? It makes be very nervous now because I am worried about the same thing happening again and being stuck out at sea.
Also, I have limited experienced with jet Skis, I pay a storage service to clean and lift my ski in and out of the water when I use it at the port. Each time they put it in the water, they check a little thing on the back to make sure its tight. What exactly is this and what would happen if it wasn't tight?
