Need some advice. In an attempt to replace the fuel inlet fitting on the fuel tank, I broke off the fitting so there is a portion stuck in the block piece fitting that goes to the tank. See the picture. My question is would anyone suggesting using an EZ-Out and penetrating oil to remove the stuck portion or is there a better solution. The boat is a 2004 so the fitting is the original. I also thought about trying to remove the the block piece but suspect I may have the same issue. I believe the fitting is aluminum so the EZ-Out may not work as well as with brass. Obviously heat isn’t going to work since it’s a fuel tank. I just installed a freshly rebuild engine last fall so I don’t want to go through the hassle of removing the engine/tank. Thanks in advance for your help.
