So the method I have used for 25 years and goes back to Group K.
Heat cycling is what you are after....
First 1/2 tank, premix and oil injection, no more than quarter throttle varying the throttle the entire time with stops to cool down every 15-20 minutes.
Next 1/2 tank, no more than 1/2 throttle 20-30 minutes.
Second tank, only premix or oil injection, not both, first 1/2 no more than 3/4 throttle same heat cycles.
last 1/2 of second tank you can go full throttle but never hold it wide open heat cycling isn't as important.
The difference between the smallest tank at 10 gallons to 15 isn't that bad and you can't hurt anything by doing a little longer break-in.
Yes, it sucks and is agonizing but do it once and do it correct.
