Boarding step
2011GTS130
I recently purchased a 2011 gts 130. It is the base model as you all know. I read somewhere that the boarding step which is available on other models is compatible with my gts 130... any response on this? Any info on how hard it would be to mount it???
Hi Guys ,
I have a 2004 Seadoo Speedster 200 .. The factory pylon i've got is pretty good however when wakeboarding the low height of it causes problems.
I was wondering if anyone knows of a way to extend the height of the pylon to 6 or 7 feet...or some alternative to the expensive tower.
Any help would be appreciated.
thanks
I just purchased a new 2011 gti se 130,and it has the boarding step. it would probably fit the gts also. it only has a bracket on both sides of the jet nozzle and is spring loaded and tips up. it should fit on your seadoo as well.
I boutht a new 2011 gti se 130 and as ansteyz stated in his post, is included. I did look at the base model first,, which did not have the step, but in the negotiating process, they offered to include it in the price. I think they said it was a $200 item and I'm sure its the same step..not sure of the install difficulty......
