Hi guys
Got a 2018 wake pro 230
Just had a new engine rebuild after a pump failure and damaging the bottom end.
Had the ski back some time and I have found a slight issue.
From stand still if I go to pin the throttle or if I am cruising in low revs and then go to max power once the ski reaches between 6000 7000 rpms it blips as in it will bounce a couple of times at that rpm drop a little in speed then it will just pick itself back up and get to then about 8000 so on etc. and maxing out around 64mph.
Any advice. Thank you.
