Broosedamoose67
I was cruising along at about 45 MPH when the ski just started slowing down. When I give it throttle, the engine revs up but the ski will only go about 5-6 MPH. It "feels" like the prop came lose from the drive shaft. I had someone skilled with Sea Doo take a quick look at it and it is not the wear ring. He said that on that MY there was a problem where the driveshaft breaks loose from the crankshaft and that may be the issue. He is going to pull the jet pump today and check things out. Is this an expensive repair? I just bought the thing! Only the second time I've had it on the water! It has 113 hours on it. I just got rid of a 2002 GTX because a seal on the crankshaft let go and the cylinders were flooding with oil. I'm not having good luck with these!
