Hiya again,
Just in the process of getting an older xp I picked up back on the water. Would like to put a water shutoff on it though in case it ever needs to be towed. I've seen the horror stories of towing without clamping the hose properly
Which type ball valves are you guys all using? 1"?
Just wanna make sure I pick up the proper one that won't create any restrictions.
Should I used the valves with the barbed male ends, or some of those fancy sharkbite ones that slip inside the valve with no clamps? I just want to go with whatever is most reliable.
Thanks!
Thanks!
