97_Sea_Doo_GTX
Thanks for the tip. I might just check that next. It is running steadily worse every time I test it out now. The thing is I'm not getting excess oil in the crankcase when it sits but maybe PTO & Mag end seals leaking??
Took it to lake this morning after thoroughly cleaning, inspecting and testing both carbs. It runs perfect in the water at 1500 rpms for about 10 secondes and then the rpms begin to drop. Run less than a minute, died and wouldn't start. let it sit for about 5 minutes. Started right up at 1500 rpms but then they began to drop again until it died again.
Took it home and started it. Idles at 3000 rpms but the rpms again drop until it dies. Took the plugs out and they seem a wet but the spark on each is strong and a nice blue color. For the hell of it I tried a new rectifier. no change.
I decided to disconnect the return line at the Y and see if fuel was flowing to to return. Started it again and there is a decent flow from the returns on the carbs at idle. Tells me this thing is getting fuel.
Here's a recap of everything I've done so far:
- Tested compression multiple times with 2 different compression tester. 145 on both cylinders.
- Pulse line has good vacuum/pressure with my finger over it while cranking. Hose is in very good condition.
- Disassembled both carbs twice. Checked pop off pressure. 36-37 on both. All passages, and jets are clear including the idle circuit passages in the throat. Internal check valves on Mag carb hold in each direction as they should. Set Idle Mix on both carbs to 1 turn and Hi Mix to 0 on the Mag carb and 1/2 on the PTO carb. Fuel pump diaphragm is in good condition. Filters completely clean. I installed genuine Mikuni kits, Needles and Seats a couple of months ago. Ran great at that time.
- Bypassed the fuel selector and water separator. New filter and o-ring in the water separator. Fuel selector is almost new. All black rubber hoses. No obstructions.
- Removed the fuel tank baffle. No obstructions and perfectly clean.
- Installed new NGK BR8ES spark plugs several times. Gapped to .22. Clipped the plug wires and installed new NGK boots.
- Replaced Rectifier.
- Load tested the battery. Good. Charges as it should with about 14.5 volts at about 5500 rpm.
- Drained the fuel tank and put in fresh fuel.
- Pulled the head and no piston/cylinder damage.
I'm at a loss at this point. I'll probably try the leak down test next but the problem has steadily become worse in a short amount of time. I would think if it was a crankcase seal the issues I'm having would progress more slowly. It started out being able to run at 6500 rpms for 30 minutes before it would gradually die but has degraded down to now running for only 30 seconds before the rpms go down until it dies. Total run time in several sessions since this all started and rapidly degraded is about 1-1/2 hours.
