Wow, so much info...I wish I could keep up...Does air intake make that much of a difference? I feel like my C180 has just a cone filter on the block itself or maybe that is something else....or the previous owner made an odd mod... I'll have to look in there again and confirm.
I'm going to continue to highjack my own post to keep discussing the intake. I'm NOT speaking from experience but just the 20+ posts I've read on SDF as well as other sites. The resounding opinion is YES on getting rid of the OEM airbox and going with a K&N type setup. People are claiming 100-400RPM and 2-3MPH with 200RPM seeming to be the real number.
From what I've read turbos and SC seem to benefit from such a setup but not NA vehicles. Additionally, if you are in salt water you still want to dump your oil vapor back into the intake on your non-OEM system to keep the SC lubed from salt air. Otherwise the other benefit is to use a catch can for the oil vapor as removing from your SC will reduce thermal load. I'm having my SC rebuilt so I want to keep it happy from day one. Also...everyone says to keep your intake as short as possible only to the point you are confident you will not have water ingress into the intake if something very wet happens. The long OEM seems to be another reason for the restrictive air.
So with that said here is my setup (see photo) that I'll have about $50.00. Spectre is the brand name we have at Pep Boys and AutoZone where I live and they were 10% off, on sale. They have a solid website too. I bought a 4" filter as well as 3-4" adapter to go on the SC. Bigger is better in this case. The filter is very well built and as good as any K&N I've seen at 2-3 times the price.
I'm going to go ghetto on my piping as I had 3" black ABS (black water) piping in my garage. I just bought a couple angled pieces so I can get my design just right. I want to go about 2ft up and over toward the battery area. If I like my design I'll prob do the right thing and get proper hosing such as listed on the sponsors sites. Starts with a K but I cannot recall the name.
Also the voltage regulator (rectifier) is placed into the OEM box to keep it cool. Most people are arguing on the forums to just hang it out anywhere and there will be no issues. It really doesn't get much air as it is with the design of the air box. Just don't tuck it in a corner or a air with stale area...I haven't determined my solution yet but it will stay above batteries prob.
Also don't use rubber hoses as they my buckle from the suction (so I've read) but stick with silicon or my cheap-o ABS/PVC. You can add pretty metal but it adds to warming the air due to it's thermal absorption properties.
lastly, everyone says you'll get more roar and SC sound with this setup...I'm not looking for that but prob won't hate it.
My goals here..
1. Keep SC dry
2. Get an extra 1-2RPM
3. Get an extra mile or two
No I'm not an expert but I did stay at a Holiday Inn Express...
