99 gtx rfi no spark front cylinder
Glennm
99 gtx rfi starts and runs no "mait" light I get 2 short beeps when dess key put on. But ski only runs on rear cylinder no matter the rpm I have already replaced the plugs and coil anyone experienced this? Any ideas before I buy an mpem
Have you checked fire on both cylinders? Check fuel pressure should be around 58psi. Are the injector wires in the correct locations? The Rave Solenoid connector will fit on the Fuel Injector so that can and has happened. Basic troubleshooting is the answer. Good Luck.
Yes checkerd spark with inline tester rear cylinder has great spark and the ski runs. There is no reason the injector wires should be switch with the rave but I could check also will fuel pressure issue cut spark? The front cylinder has 0 spark not weak spark
