Hey,
Have a 99GSX Ltd. I am replacing starter on. While doing that I noticed there are no shims on any motor mount. The local dealer won't work on anything this old so I am looking for some advice about alignment. I was thinking of installing the pump without the shaft bumpers and without the Carbon Seal set-up. This should allow me to align the engine until the shaft floats forward and back with little friction. Then, pull the pump and finish assembling it. Any thoughts?
Also, can I replace the current Carbon / Hat get up with the old style bearing and seal? Will it fit the shaft ok and will it work?
Gymski
Gymski
