**update bendix is bad**
So from what I understand I got 1999 seadoo gsx limited 951.
Few days ago I died on water paddle back though battery was dead was right about that then I charge the battery but the ski was kicking the starter for few seconds and cut out only one time it start but I shut it off.
Every time I try to start the engine it will try but won’t start and some tryouts will make weird noise.
I open the mag cover and the bendix need replace the starter end shaft is bent due to old owner not putting the starter screws.
1) when I put the pipe head back on do I need to put anything to seal between pipe and engine head? And also what about the pipe extension with the ring lock do I need to put somthing there?
2)for the shavings I found inside the bendix and starter area how I clean that out without damaging anything else.
3)all fuel line was replaced except the one that comes from the tank this still the gray line
What fuel line I need to get for carbs fuel line and the main one that comes from the gas.
4) where can I find good starter?
5) what tools I would need that maybe I can rent to remove flywheel for bendix replace.
6) I also keep blowing the fuse with the name acc what is that for?
