Grim
I inherited my dad's sea doo. It is a 98 GTX limited and the engine (rebuilt) has less than 15hrs before it was stored. I got it home and it looks like rodents tore up the wiring pretty good and some of the insulation on the sides (in engine bay, looks like Styrofoam). I am pretty mechanically inclined so i am going to see if i can get it to run. I have poured through the threads and found a lot of good info but this is my first PCW. I have put some fogger in the cylinders and I have ordered about half of the wiring for this sea doo. I will be draining the gas and oil tank and will put new stuff in it and check for leaks. I plan of running it rich for the first tank to help with it sitting so long. New spark plugs and wires. Checking all hoses and will replace anything that looks damaged. There are no gray fuel lines on this one.
With all this work i still have a few things i couldn't find...ie I still have a few questions:
1)What do i do about the damaged foam that is on each side, in the engine bay. Like I said it looks like Styrofoam but I haven't seen where i can get replacements or how to fix what is left over from the rodent's nests.
2)I am going to rebuild the carbs ....or should i look for rebuilt ones. I can do it myself but not sure if it is worth the hassle. Anyone have the rebuild kit number/with jets off hand?
3) Anything I should check before trying to start it up? Other than spark plugs, fuel filter, fuel lines(they are not gray)? Already have a new battery.
4) I would like to start it up in the garage and do as many checks/inspections as I can. Can I start it up without it being in the water?. I read about the garden hose adapter but did not follow what it is for.
5) I plan of doing a compression check once it is running, i figure it should be around 145 each cylinder …right? or should i do it now to make sure the engine is healthy
As always any advise or links to more information would be apricated. I am looking forward to getting this beast running and in the water...maybe this summer!
