98 GTX LTD fuel routing for carbs
Grim
I am installing my carbs back on the engine (951) and I guess I neglected to take photo's of the hose configurations, looked in the manuals and some of it is not as clear as I need. I want to verify I am hooking up the right hoses to the right connector on the crabs. The picture attached shows all three hose ports on carb. The one on the right is the main fuel line, the one on the left is the return line and the pulse block connector I think goes to the port in the second picture. It's on the block right past the starter. Is this correct? Yes, I will clean the nipple, didn't know that was even there.
That’s correct.The other hose goes to a one way check valve then on to the rave solenoid.
