98 gsx limited long beep every couple minutes or so
It could be a LOW fuel indactor...it will do that so you know to add fuel. Check the fuse and see if the connector is tight and clean at the fuel sender on the fuel tank. It will have 2 wires coming out of it. Pink and Pink/Black. If it's connected and fuse is ok, I'd use a multi meter and see if the 2 pink wires have resistance, based on fuel in tank it will raise or lower depending on height of fuel level. If you get no resistance it is the sender in the tank. Remove the clamps and pull the baffle tube out and pop the bottom off it. Inside are magnets that slide up and down with the fuel level if they are dirty or missing here is the problem...Clean or get them out of the tank and reinstall them. It should work now, so recheck with the ohm meter. Post back if you have any other questions.
Karl
