Hi All,
Currently my 97 GTX is giving me fits: It displays low voltage & previously would crank while displaying, then later the starter solenoid would only click, and now no clicking or anything. Battery is good & I get the 2 beeps when I plug the safety switch lanyard plug on. The battery is reading 12.5 volts & drops to 12.3 volts when I press the start button. I am trying to trace if I have a bad cable or connection somewhere, but also think it could be a bad electronic module. I opened the rear electrrical box & found the seal was out of its groove & water was standing in it with a lot of corrosion on the solenoid & ground terminal. I cleaned all the connections - no change. There is no voltage drop through the positive cables from / to the battery - solenoid - starter.
I tried to trace a bad ground but haven't gotten very far - the wiring diagram doesn't show a ground wire going from the battery to the front electrical box. A light guage ground wire goes to the ignition coil & solenoid in the rear box (good continuity) & the heavy ground wire goes to the starter motor - is the engine block the common ground for the electronics?
The fuses in the front electrical box are both good, but since the module is potted it isn't easy to check voltages / continuity etc. there.
As I write this, I think the corroded starter solenoid might be the problem (I sure hope so!!) & will next check if I get positive voltage at the Y/R wire when I press the start button, & jumper across the solenoid to see if the starter will crank properly. But, that still doesn't explain the low voltage display this sled has shown for a long time even before it totally quit.
Any ideas or feedback is appreciated!! Thanks, Jim
