My XP won't fire up without a charger on the battery. It will turn over pretty good once it gets past the compression stroke but I won't have spark.(spare plug on the lead) I just realized yesterday that every time I pull a plug out to check for spark with the plug I pulled, IT FIRES UP!!. That has happened 4 0r 5 times in the past but I always thought it was an intermitant ignition issue. Now I'm thinking it has to do with the drain my battery is getting from cranking is taking power from the ignition system. Any thoughts on that from the Gurus? It will start occaisionally with the charger on high and I haven't tried it for 15 minutes or so. (Fully charged Battery).
