96 XP and 97 GTX for parts/rebuild
acbprop
Here's the deal. When I got these last year, the XP was running but not well and it had original fuel lines. So I replaced lines, cleaned fuel system, rebuilt carbs, even had new fuel tank installed under warranty. Unfortunately, during the process I apparently dropped something in the engine and when I started it the rotary gear was stripped and the valve and surfaces were damaged. Motor has good compression. The GTX had gotten wet. The motor is seized and carb is corroded. All electricals and mechanicals seem to work on both skis. Motors have been removed and all parts are there. I just don't have the time or guts to rebuild them. Cosmetically very good, seats good, come with good covers. Located Tampa, FL. I have clean titles. Email me at bobm@acbprop.com if you're interested in them or parts. No trailers. I am legit, in the marine business, no surprises here.
Need parts
Looking for a working fuel sending unit and ingition switch with key for GTX
Is the bottom end on the 787 good, I need cases and ballance shaft, will take the whole bottom end
I'm intrested in the GTX seats if they are in Good condition also the handlebar pad and the Start/Stop button. also the rear corner rail pieces
Please let me know if these are still availible
