Staccato
Hi guys. I’m brand new to the jet ski world, so bring on the hazing - but let's wait until I actually get this puppy out on the water.
My gifted-to-me '96 Sea Doo XP 800 won’t start - there's no click or anything.
When the lanyard is first attached, all four lights light up then they go out after 1-2s. Fuel gauge lights up and stays on for bit. VTS works (I can hear it move).
But when I press Start, nothing happens. No sound, no movement - nada.
I’ve looked around the forums, but couldn’t find a specific answer. From what I’ve learned this sounds like a fuse or grounding issue. Thoughts on this?
I think I found the fuse location (white box in front?), but removal and disconnection seems a little tricky with my fat fingers. I don’t mind to do it if I need to, but I wanted to check here before digging in.
Grounding appears good (lead from solenoid area to the tow hook?), but how can I be totally sure?
Any chance it's a solenoid issue? I believe that I'd get a click sound without a crank if that was the case, but I'm willing to try the jump/screwdriver thing if you think that will help.
Other info that may be helpful:
- Battery is brand new, and tests good.
- There is (was) a “battery drain issue,” so the previous owner added a battery disconnect switch in-line (negative side) a while ago. He suggested always disconnecting the switch when the machine is not in use. It has apparently run fine since it was added (until now).
- The Start button looks pretty ratty, but it doesn’t look like the ‘seal’ has been penetrated. Is it possible the button is dead? Is there a way to test this?
- VTS physically works, but the gauge doesn’t.
Thanks in advance for the help!
