96 GSX ground wire ?
hackdaddy
Hi..
Getting ready to get out soon and put a new / rebuilt starter in ...
charged batter over night and low and behold the black main ground is not hooked up...... obviously when the starter was put in the ground wasn't reconnected ?
My question is does the ground go to one of the mounting bolts on the starter...
thanks,
hackdaddy:hurray:
is there a bolt to hook ground too ????
i'm not a mechanic but this seems simple, is there bolt down by the starter where the main ground hooks up too... can't see anything down there i'm dazed and confused......
got 5 hours out of this ski last summer and all hell broke loose, now i'm thinking this ground wire shook loose and that was my problem...
stupid in seattle
right behind your starter feel the bottom of your motor by hand you will feel a whole, find your old bolt, or buy a new bolt put it through the connector in the ground wire then thread it up untill tight in your block.
Thanks for correcting me Chester, I was mearly trying to help out, but you have steered him in the right direction.
