95GTX No Beep, No Gauges
Naren
My 95gtx starts and runs fine but when I put the lanyard in, no beeps and also none of the gauges light up or work. Fuses are ok and the gauges itself seems to be ok. Any ideas what may be the problem? Thanks
My 95 GTX doesn't beep at all I believe the 96 and up will because it has the DESS system. The 95 has the old style lanyard and MPEM (no beeps)
The 95 has a modular and not a DESS,(Digitial Electronid Security System). I would check your ground and both battery connections to be sure it is getting a good connection.
Keep us posted on your progress.
Karl
Are there any other ground connection other than the main ground from the battery?
The battery ground is good and the jet ski starts and runs fine, it's just the gauges not working at all.
