06 seadoo gtx sc
originally had a charging issue with this ski after testing a few things found the stator was bad.
Replaced stator now ski charges properly, but now i have an issue with the gauges.
When you first put the key on the DESS, Gauges turn on. Do the normal sweep show the hours and everything. I get normal beeps like you would when the key is on.
Then i get one long beep, the gauges stop working. it just says "seadoo" on the gauges, pull the key everything goes blank. Put the key back on, and you get the same thing every time.
The ski fires right up and runs no problem.
I've checked the fuses, driven the ski.
Not sure if anyones had an issue like this or could point me in the right direction
