ParamedicCurt
I have a 2003 Seadoo GTX-DI (Rotax 951) that I thought only needed a fuel pump. A couple thousand dollars later and it still doesn't run. SO, I've been back tracking my work. It needed a new top end. I've included screenshots of the compression before and after. The picture of the piston is the original. My question is, I installed a WSM STD size piston. The machine only had 86 hours on it, so I couldn't imagine it had anything other than the original parts (and being my first project, I didn't have the tools to measure). IF I'm reading the piston right, the cylinder has been bored out to .045 over right? I didn't know at the time what those markings meant. And a STD size piston would be outside the tolerance? Could that be the reason it won't run?
At this point, I'm just about to buy a new core with a warranty so I can sell it and recoup some of my money. Please help! I'm just a guy with a carport and a few tools trying to fix something to ride. Now, I have no choice but to sell and start over. BUT, I DO NOT want to screw the next guy like I got screwed. The guy who sold to me SWORE the engine compression was 120+.
Another question: IF I were to buy STD bore cylinder sleeves and have a machine shop put them in, the STD pistons I installed would still be usable, correct?
99.6 and 116.6 are the MAG piston before and after
107.4 and 108.4 are the PTO piston before and after
I've done SO much work to this machine! And learned a lot along the way!
I've stripped all the old decals. Recovered the seats. New grips. New fuel pump. New reed valves. New fuel pump. New fuel injectors. New fuel and air regulator. New air compressor. New hoses. All the electrical connections have been cleaned and gotten new dielectric grease. The trailer has new lights, new fenders, new tires, hubs and bearings. IF I can get this running, someone will have a SWEET machine.
