PolarCelsius
Ski has a dead starter, owner fried it from it constantly cranking, solenoid fried too, I put a new solenoid into it and it clicks again, doesn't turn over because I know the starter is dead.
As soon as the key is attached (pre DESS) the solenoid clicks, and is constantly getting energized, pull the 5amp fuse from the MPEM and it stops, put it back in, it stops, press start button or reseat key, goes off again.
I cut the start button right at the button to expose and seperate the wires because the button sucked and thought it was always being pressed, it could still be shorting down the line though, a new button and wires are coming in the mail.
I have a voltmeter, where should I test?
