95 spx no fuel to carbs
check the O-Ring on the fule filter, you can take the filter off and hold one side with your finger and blow in the other side aka a pressure test.. or make sure you have your baffle breather vent on right so the tank is venting... makre sure the valve is turned to on... dripp some gas in the carb to prime it...
