You may want to check a little more about your problem so that your new engine does not have same problem. Not mine but does seem to be very wise.The 587, 657. and 717 series Rotax engines use a Mikuni injection pump with external one way flow check valves, mounted to the pump via banjo fittings. Many times if the valve does not seat properly for what ever reason, you will end up with a crankcase full of oil. This will normally not occur overnight, but will show up over a period of time, specifically when the ski is stored for any length of time, longer than several weeks. The conditions described by this patricular member would indicate that the check valve could very well be the cause. Numerous times in the shop, our junior techs would assume that the RV seals have failed, only to perform a pressure/leakdown on the crankcase and find nothing wrong. The next step would be to inspect the injector pump, and invaribly one of the two check valves has stuck open.
With extremely long term storage skis, this can result in oil filling both cylinders, as the oil will penetrate beyond the RV and into the covered intake port.
The Sea-Doo part number for the check valve is 420956010 MSRP is $8.43, the sealing washers are 404146600 MSRP $0.67.
This would be a good time to replace the injection hoses 414413800, MSRP $0.79 per foot and clamps 290853843, MSRP $1.24. I sure hope this helps. Robin :hurray:
