Timing.........
It seems your pretty versed on the theory of an engine, if you understand "advancing" the timing.
These engines are put together with it set. There is no real "timing" to work with. The only thing that may be at issue, is the pick up coil which tells the plugs when to fire.
You have a generating coil and a lightning coil that are adjustable. But, if you've not taken it apart and you've got spark, then this really shouldn't be of issue.
You can shear the woodruff key, then the crank spin a bit over, not sparking at the proper time. But even chances of this occuring, is slim. It is a 93 model, so I wouldn't dismiss any of this.
You should never, NEVER use any type of starting fluid containing ether. There is on oiling properties and can actually blow out your seals if it does hit.
If your sure you got spark, take about a cap full of gas and oil mix, put into each spark plug hole and give it a try. ........post again.
What was the results of the compression test?
