I got the jugs and manifold off after taking off the pipe elbow. Didn't have a 14mm deep socket to get at that nylock nut on the pipe clamp but a 1/2 deep socket got the job done without buggering the nut.
Good news and bad news.
The good news the spring is nowhere to be found. The bad news is it looks like the forward rotary gear seal is leaking and the bearing is bad. The crankcase is nasty with oil on the MAG side, but no metal or bearing cage pieces. No signs of any metal going though the engine. Anyway, so it's new crank time ... maybe even new engine time. (or rebuilt engine) The PTO crankcase is squeaky clean, no oil, no rust, no noises, no spring.
Some of the water passages under the MAG jug were clogged with sand. I don't know if that caused a local overheating problem that may have contributed to the seal and/or bearing failure. We have a beach on our lot and park the Doo there during the day so when we back up and take off, sometimes the pump will bottom out and suck sand.
Everything on the PTO side looks cherry. The MAG piston has carbon buildup on the skirt by the exhaust port. The top ring is free but the bottom ring is partly seized on the exhaust side. The rest of the way around to the gap is still free. I don't think the ring is seized from heat or hammering, it looks like burnt oil, or some kind of carbon gook has it frozen in the groove.
Even though the compression was 160 on both cylinders I think by the time I replace the crank and clean up the MAG
piston/cylinder ... it is probably time to think "new engine" or rebuilt engine.
The kids are starting to outgrow wanting to be towed by the SeaDoo and want to be towed by the boat which throws a lot bigger wake. The little ones don't really like riding the X4 hull since to them it's too tippy when it stops or turns slow.
I'm not sure whether to sell the Doo now or put a rebuilt engine in there and run it for a year or two and sell it before the rebuilt can blow up. I already redid the whole fuel delivery system, rebuilt the carbs, put in a new agm battery and rebuilt the VTS. My 22' Hurricane deck boat with a 200hp Merc goes almost as fast as the SeaDoo so I'll use that as an alternate expensive hair blow dryer.
Any suggestions on where to get a rebuilt engine that will last a few years without spending more than the Doo is worth? I snapped one head bolt. Will most rebuilders take it as a core tradein?
