I took the thing out today and had a good time on the water going 30 mph and never getting above 5k on the tac. Tonight I was cleaning the boat and discovered that the wear ring seems to have a rather large gap in it. I am no expert nor do I have the right tools to measure the gap but from what I could see, I could possibly fit a nickel (def. a dime) between the prop and the ring. Now I know that it is time for a new one at that gap but do you think that it would be the cause of my low speed and low rpm? Also, is it worth me ordering the ring, the prop puller tool, the smelly oil that goes in the cone and everything else to replace the ring, or just take it to someone to have it done? I am fairly mechnicaly inclined so I feel if it is not too bad of a project, I can do it myself.
HELP!
PS: Thanks to all that have helped me out in the past and I know that everyone is sick of getting wear ring questions without searching the thread but I have not found anyone with similar problems as me and I dont want to go spending the money if it is not going to help fix the problem. If I should just be satisfied with 30 mph then so be it.
Here are the previous post related to my boat and its saga if you want to read and see if you think the ring is the problem.
http://www.seadooforum.com/showthread.php?t=4503
HELP!
