Just rebuilt 210hp M2 1st thing I ever rebuilt. Had 1 bad cylinder bored and oversized. Motor is in but when I try to start it spins then just a thunk like it wants to start but stops immediately. Remove plug wires and starter spins flywheel no problem. Help please
tested stator and trigger - failed. I ordered a CDI. question now is CDI wire directions say yellow collar goes to piston 2-4-6. Manual says 1-3-5 as was wired that way with OEM. Will I mess anything up if it is wired backwards depending on which directions I follow. Waiting on new stator it tested bad also. Its weird B/C everything worked before I rebuilt.( Everything did sit in garage for few month before I put it all together though). : Back story I bought this without checking compression. only run test on hose. So this is new boat to me and obvious bad piston at purchase. And I never rebuilt an engine before period. But I dont think I did anything wrong B/C I followed manual and Im pretty mechanically inclined. It was fairly simple. thanks for replyAre spark plugs wet when you remove them? yes
Are all carbs full of gas? sprayed start fluid
Any loose wires? bad wires on trigger and stator some deteriation
Has ignition timing been properly set? With travel indicator that screws into cyl. #1. I didnt mess with it and Piton 1 at TDC with the 0 on the flywheel. not sure what travel indicator is. but I just put all parts and wires back exactly like they were.
Have you checked emergency kill switch function? You probably don’t want to hear~ what are your compression numbers? 90 on all cylinders as before rebuild was 90 on all and 0 on #4 thats why I rebuilt.
did all work myself. extreme novice but mechanically inclined. No smoke because it never started. did spark test no spark at all. tested trigger and stator both failed ohms test on 1 test point. ordered new parts. I think the thunk must have been just the motor abruptly stopping after just cranking a while. After testing spark and getting 0 obviously it didnt try to start. Trigger arrived but not stator. CDI part. Wiring directions says yellow collar goes to 2-4-6 but manuals say 1-3-5. Im now confused and scared to connect it backwards. Will it hurt anything if wired wrong. Yellow collar has the extra tan wire jumper that goes to control module I think.Welcome.
Since you are new here it might be fair to ask if you did all the work yourself.
Any how much experience you have.
Is there any smoke out the exhaust after the "thunk"?
Are this the wires you are talking about?
Tim, yes those wires have damaged insulation and will require repair before install.No. That is the engine stator; AKA alternator. Are those chafe marks in the RH pic?
The stator does not move. They don't fail very often, unless you have a bad battery. That can burn up regulators which can burn up the stator.
The trigger fits inside the stator and moves with the throttle to change ignition timing.
When I had to change my trigger, I unplugged the bad one and plugged in the new one. 6 wire connector. Engine cranked right up.
Is this the trigger coil?
Also it seems as starter drops out as soon as it gets a little resistance from motor maybe trying to engage. Not sure if explaining it accurate. But it turns over and over then the sudden deep thud almost like it would start if it would finish that revolution but it doesnt the starter gear drops out and I have to turn key again and start process of starting all over. Or sometimes it seems as if it pushes pass that with little resistance of maybe 1 second and just cranks again and again.
Do you know what head temp. should read with laser gun while Idle on hose. my manual only shows pressure not temp at 1100rpms and 2400 and 5300 rpms. I just started it this afternoon and alarm goes off after few minutes of running. s-side reads 145 and P-side read 135. Thinking maybe bad sensor or something to do with oil pump removed. Same alarm I think. Thanks for help because as I said Never done this before and all these problems keep making me feel like I did something wrong. Not sure what good running engine should sound like but nothing sounds any worse than it did before. 2 stroke kinda noisy anyway. oil mix is 20:1 instead of 25 so should be well oiled for break in.very good progress.
I had whole engine completely apart and adapter off the boat. engine looks like new inside and out. definitely no corrosion any where. Also hoses are clear. When I bought it it never peed from the hole while on hose. I would say not enough hose pressure because the alarm is what started this project. It ran hot first time I took it out. Checked everything with cooling system then decided to check compression before taking heads off to look for internal blockage or leak. Found dead cylinder and thought that was it. Rebuild engine ran into all these electrical setbacks and now back to square 1 Over heat alarm. Now I pulled the plug on top and watched the water rise to the top. So engine is full just not enough pressure to pee it wont even push out top hole with plug out. Measured head with laser after 5 min. run time it read 150 at center cylinder top and cooler at bottom different temps all around on both heads starboard side is 5 to 10 degrees hotter than port. Tried pulling wires 1 at a time off sensor. alarm didnt silence. Then Solenoid stopped working wont restart tapped on it gets a few cranks and cuts out before starting engine. So I quite and ordered one. This project is certainly sharpening my troubleshooting skills. But since I never done any of this before it makes me second guess if I did something wrong. But that is usually how electronics goes 1 thing after another. Engine running sounds as good as any 2 stroke to me but what do I know. See attached video for your opinion is appreciated.( video is around 1200rpms). Still a little sluggish to start first time. I'm wondering if the enrichment solenoid is bad b/c it seems to start easier after I press the manual button a few times. Start Solenoid will be in Sat. Guess I will mess with it again on Sunday. Thanks for your help.
