xintersecty
Alignment was easy using the tool. It was on rainy crappy day and I had to be super careful climbing on/off the boat.
Here is the oil filter (see how clean! ) before the cap goes on
All the electronics back on and fuel rail.
There is a lot of sensors on this boat and a lot of connectors. The biggest pain is the ground connectors. They are under the oil fill and use a 10mm bolt. It's hard to see and maneuver there. It took me a good thirty minutes to do three bolts.
Once I got the battery in the boat, the engine electronics would power but not the front console nor bilge pumps. I finally figure out what was wrong. The ground connector to the batter for the secondary electronics had fallen deep in the boat and I had missed it. Put that back on and my secondary bilge pump fired right up. However I will have to reroute the drain and electrical cable. They do not fit under the exhaust.
