Tiggo
I have the same Ski and love it. It sounds like you have 2 problems. Electrical and fuel. The rectifiers when bad will let the ski run at about idle or slightly faster but don't usually shut off the ski. It just goes into a limp mode. Also, the voltage on mine goes up to about 13.5 when cruising around. It needs to recharge the battery. If yours only goes to 12.44 then that is a problem. OSD's rectifiers are still Chinese and they may have gotten a bad batch. I find it hard to believe that both stators went bad. Did you test them? My other thought is your fuel pump and filters. Do the pumps come on when key is plug in (5 secs)? Check the fuel pressure. Pull the pump and replace the filters. It they sat while you rebuilt the motors, perhaps they gummed up. Keep us posted on the fix.
