CantComplain
Hi All-
Went to install my "new" engine panel (so much quieter!) and noticed the bilge was full. Basically about an inch over the top of the pump which, not surprisingly, wasn't working. I bailed out about 20 gallons, which is more than I would have guessed it held, and pulled out the Rule-Mate 500GPH pump. It was cracked through the spinny bit and is irreparable. Probably hasn't worked for 10 years. Replacements are cheap but I'd love to use the same model so I wouldn't need to pull out the cage that's riveted to the bilge floor. But I can't find that model which I assume is original. 200 Optimax if it makes a difference.
So does anyone know if that's still made, and if not, it's it's OK to drill out the rivets and screw down a new one? Is the 3 wire harness standard or will I need to splice it in? I assume that would be the solution but want to check before drilling holes....
TIA
(also, not sure if the syphon is working as I would have expected that to drain the bilge. Guess I need to look into that as well.)
TIA
