2 stroke leak
Hursty46
Hello I’m new to your forum I’ve recently Purchased a Seadoo 951 gtx limited edition 1999 2 stroke bought as a project replaced plugs cleaned carbs replaced water box got her up and running I’ve noticed a leak of 2 stroke oil in the hull of the ski at the back under back seat area I’ve tested the 2 stroke tank when I had it out no leaks from it whatsoever my question is any ideas please where it could be coming from new to jet skis so I’m learning as going along thanks in advance
Thank you for the reply the oil tank is perfect when I removed it to change sender & clean it out I filled it with water and blocked off the feed line end left it around 3-4hrs didn’t loose a drop of water it’s got to be a hose somewhere will take a look over the weekend and post back my findings thank you
