There’s two bolts that need to come off that need to go on the bracket, was thinking taking one off then loosely put it back in with the bracket, and when taking out the second one, get the threads started. Then tighten them both down.Yes, you should be fine putting the bracket on but if possible just do one bolt at a time.
alright good haha, i'll put down a towel underneath the carb so I don't loose those bolts to whatever lies underneath there.The cable bracket? If so yes, you can remove both bolts and put the bracket on and it won't hurt anything, we have all done that once or twice.
Usually it is as simple as turning the arm the correct way.
So from what you can see the pump looks aligned? I have it so the carbs are sitting on the idle adjuster with slight play before the throttle begins to actuate.double check the oil pump marks are still aligned.
Almost ready for the finale moment, got the exhaust mounted, final fuel lines ran, cleaned some connections that would've been hard to reach with exhaust on. Will send pictures later today.I would clean the pump arm and pump as the dirt and oil makes it hard to see the marks but it looks close.
You can run it out of the water without the air box but you need to have the carb braces installed.
Never run it on the water without the air box.
yeah that's what I'll do when the weather clears up, got some new plugs today but wont be able to test from all this rain.No, leave the pump arm adjusted correctly.
Put a little premix down each carb and start the engine. With it idling reach down and hold the oil arm wide open with your hand until the oil lines fill up.
Yeah that's why I called it the killswitch rather than the DESS post, weird though since when I first found that out I thought all 96 models had it except the HX which was neat. I think I will just replace them both but keep the original solenoid on hand as a backup.If moving the lanyard fixes the issue it's probably the kill switch. THe 19996 HX just uses the old simple push button kill switch, not the DESS one.
