1993XP657
Update: Donated another 5 hrs to it after work a few nights this week. Rebuilt the starter again tonight with an OSD kit as it burned up the brushes again, with similar results.
Jet pump is off and wear ring was slowing engine down for sure. Verified 150 psi in both cylinders today with my Snapon compression tester. Jumped starter switch and also went thru fuel system, bypassing fuel selector switch and strainer and added fresh gas after siphoning out all of the old fuel and a clear fuel filter like my other skis.
I have strong spark and have swapped a known good cdi box from a 96 xp I'm working on for a customer. Carbs have been rebuilt with OSD kits as well. Won't start on starting fluid either or mixed gas poured into carbs. I pulled rotary cover and double checked the rotary valve timing with my wheel and it's at 145*.
Still no start. Will act like it's gonna start and then the motor slows down and starter will disengage. This is getting out of hand. I'm out of ideas.
If the flywheel keyway was sheared, wouldn't it backfire?
