Well I had the boat out today and things didn't quite go to plan but it does float and it does work.
The issues I'm having I need some help with.
First of all I sprung a leak in the exhaust where the little plugs are welded in, is this something I can repair with an epoxy metal or glue?
Next up I seem to be having performance issues, with just myself and half a tank of fuel I only managed 46mph flat out, I was expecting closer to 60 ???
This may be related to the top speed issue but I also found the engines revved up easily and would hit 7000 rpm at about half throttle, I could easily go full throttle then once at top speed pull the leavers back and still stay at top speed with slot less throttle.
I know the impeller are different in my not as it only has one intake but I found some odd issues that may or may not be related to this.
First of all I had to constantly turn right when the revs on the 2 engines were matched, the reverse worked better on the right engine and the left engine seemed to accelerate slightly slower than the right when going from idle to full throttle.
Anyone got any suggestions as to what would cause these issues?
I have 2 new solus impeller ( correct ones for the boat), new wear rings, new drive line bearings and seals ( not fitted with carbon seals) new neoprene seals on both sides and thought the drive side of things would be perfect.
Many thanks
Andy
