wlester
The 12V outlet on my 2004 4-Tec never worked and was just rolling around in the electrical wire area. I asked the Seadoo dealer how much it would cost to replace it. He tells me $125. I figured I would live without it.
$125 my ***. $4.95 on Amazon.
http://www.amazon.com/Marine-Grade-...375395895&sr=8-7&keywords=marine+power+outlet
As long as you can just feel around for the positive and negative slots, you should be able to get them attached and then screw the plastic nut on from the inside.
Replacing was easy. I turned the power on and tried it out. I had a small automotive vacuum cleaner that I hooked up. It started, then died. I figured I blew a fuse. I checked the fuses, and all appear to be fine. I checked the main fuses by the battery and they were both fine.
What am I overlooking here? Can anyone give me some suggestions?
Thanks.
Thanks.
