OK first off, i have done a little searching around oh how to do things etc. I have an 07 speedster 150 with the 215hp motor. Great boat, a joy to drive never had any issues.
Now the last time i took it out i noticed that the little threaded cone thing on the shaft side of the pump had backed off ( a common issue as i read) and i had some decent cavitation problems in the hole shot. I also noticed my impeller has some decent dings in it and from what i can see the wear ring could probably be replaced.
So i know that im going to be pulling the pump off to at the very least thread that cone piece back on. but i figured may as well replace the grease impeller and wear ring.
SO to the major question. WHAT impeller and wear ring do you guys suggest.
I see the solas concord SRX-CD-14/19 is a "stock replacement" and at the ~ 250 i see for it online its not bad. But what other options are there out there. Im not looking for performance i just want to get her back up and running in tip top shape... this cavitation sucks.
And for the wear ring, OEM? aftermarket?
And lastly best place to buy these items?!?!
~Thanks
~Thanks
