Dealer winterized - normal 1st in water routine, fill with premium gas, add STP Injector cleaner as I have done for past 5 years. Launch boat - wife drives to dock, said was running rough while I was putting trailer away. Next day, attempt to go out but engine was running real rough (battery was run down) so I limped back to dock. Test battery (4-years old) replace with fresh new one.
New battery - hard to start, real hard. Not smoking, just cranking. Manually hold throttle open and she starts and sounds like normal. Take for spin on lake - no top end which is usually 40-45mph +.
Thought possibly water in gas would be cause after visiting this forum so I added bottle of heat to the mix and still the same performance which is 5500rmp = 20mph.
Enough background - its 6:50 in the morning, I am thinking I have fouled plugs and was going to take the hour ride to SeaDoo dealer and purchase new plugs.
Thought was once I get back to the boat - pull plugs and see if they are oily or not however new plugs are always a good investment IMO.
If new plugs don't do the trick, then I am thinking blocked impeller, wear ring or worse of all - dinged up impeller.
Any thoughts are most welcome.
Morning2ya'll
Morning2ya'll
