Hey Guys im on vacation and try to start myn seadoo 155 gti.
No start, i hear 2 beeps, cranking cranking it starts but falls out. Then after more cranking it was not cranking anymore. So we checked, in the front you have the relay of the starter that big thing where the + cable from the accu direct enter. So changed that one an then i dont have ingination. Checked and the relay was not fine ( the 5 pins relay in the box front side ). Repaired little bit. Now i hear the 2 beeps but i dont have fuel or spark… i have 12 volt on every bobine and injectors. I know the ecu give the ground signals. But i dont have any ground singals to the bobines or injectors. Can me ecu died when we are trying to start the jetski ? Also if i look to the cps, i have around 900 ohm but just 0,5 volt. . Can someone help me where i need to look at ? I have 4 ground cables to myn ecu and all of them have ground.
