turbosl2
I am finally getting my 08 Challenger 230 SE back together. The only thing i do not have hooked up are the tachometers. I went to start the motors (individually) and its apparent that the port engine idles much higher. I obviously dont have the tachs yet but should i be worried. Do the ECUs sync the engines using the tach signals? If this is the case are the tachs needed to do this? I am trying to determine if the higher idle on port is even a problem. I cant start both motors because I only have 1 hose. I would have to make a splitter. The lake is 45min drive each way so rather figure it out on the trailer first.
