2007 Speedster 200 430 HP throttle sync
4stfire
The throttles seam to be out of sync on my 07 Speedster 200. I see points in the cables for adjustment, but don't really know where to start. The port side is 500-750 rpm less than starboard. I am able to use the throttles separately to make up the difference, but would like to have them equal to make things easy and be able to pay attention to everything other than the tachs. anyone made these adjustments? Thanks in advance, C
Is there slack in one of them? Pull both throttles to idle then check deflect the exposed wire from the cable at the throttle body while holding the throttle assembly closed.
If one of them has excessive slack, just use the adjustment to take it out.
If they appear to be the same, you can try to adjust but any adjustment beyond slack would have to be made through trial and error while running in the water.
Agree with Mac, cable slack and age are huge contributors to variations between the RPMs. I'd start there.
