I have a 96 SPX and it asks for 36 to 60 psi for pop off. I'm getting 36 on one side, just under 40 on the other. I upped the needle from a 1.2 to a 1.5 and kept the spring that came in it. Should I use one of the other springs or even with it being on the low side, is that ok? It holds pressure just fine as well. I've read you can bend the arm that touches the needle to increase pop-off but wanted to confirm.
