I bought a 1997 HX back in the spring...the last year it was registered was 2015 so it has pretty much sat in the woods for 5+ years. I have worked on it all summer and taken it out 6 or 7 times. One ride will be great but the next ride will have an issue. Now, it is dirt and grit in the fuel. I am not sure where it came from but I think it was a local gas station. Anyway...dirt/grit is getting past the fuel filter/water separator and causing issues. I have removed the cards twice, cleaned them, and replaced them only to have it happen all over again after 2 rides. There isn't alot of grit/dirt in the bowl but there is definitely some there again and I am sure there will be some in the carb filters and inside the carb as well because the HX will run great then just fall on its face when the fuel gets cut off by somewhere. I have drained the tank twice with a siphon but I haven't put rags inside or anything else to REALLY clean up the tank. I have strained the fuel each time and I really didn't find my dirt/grit in the strainer so I think it is OK only to have it happen again. I read the thread at Link and it seems my only two choices are to 1) remove the motor then the tank (to clean it) or 2) siphon the gas out and put rags and fresh gas in the tank to try to clean it. I know an inline filter is an option as well but I have read mikidymac's post and if he says "no" then I will trust his experience and not put in an extra filter.
But...I am worried that I am so focused on gas/carb now that the issue may be electrical. Unlike before this time pulling the choke would kill the motor. I just looked insdie the carbs and they seem to be pretty clean...no obvious dirt/grit/crap in the filters or inside the carbs. This last ride I experienced something a little different. I was just going down the waterway at 3/4 throttle and I felt a quick "tug" like the motor missed for 1 cycle. Then it ran well for a while. Then it would get worse. Then after about 1/4 tank of fuel it wouldn't get up to half speed at best. Surging then nothing then it would be fine then surging again and again.
I am wondering if I should start replacing components like the rectifier, coil, electric module, spark plug wires, etc. I am really tired of chasing this thing all summer.
I would love to try one electric component at a time but my biggest problem is testing. For me to put the ski in the water and try it out is a big ordeal. Not easy to test something then put back on the trailer and work on it in the parking lot...in 95+ temps...in the sun.
Any suggestions would be great!
