ddanster
I'm about to give up on this machine and cut my losses..really don't want to spend the on season tearing this thing apart. Anyways to refer to previous posts I ran this machine last summer and had issues with starting it up. It would run at full speed just fine and had plenty of power. I spent the winter replacing all the fuel lines, rebuilding the carbs and verfying all systems. The carbs pass all tests according to the manual and are as clean as can be. Also replaced the fuel selector valve and recently bypassed it to see what would happen with running.
The issue I'm having on the water now as it seems to hesitate and flatten out at halve throttle. I'll fully throttle it and it stays at half speed then suddenly it will take off and reach full power and run well for a few seconds then abruptly cut out as if its running lean or starving for fuel. When it cuts out like that its hard to start but eventually starts. It definitely feels like its struggling at times. This particular engine does have a compression inbalance..one cyclinder is about 140..other about 127, at least when I tested it during the winter. But it ran fine at idle, mid and full speed last summer with those compressions. Perhaps I have a leak at the crank seal? I didn't take apart the fuel baffle should have I? Fuel pump seems to work just fine. Any help is appreciated!
