Hi I have a 96 seadoo gtx with a new engine that won't accelerate or run right when it is given WOT it will probably get around 3000 rpm (not sure rpm gauge doesn't work) and will push water as if it is about to get up on plane but won't. I have gotten it on plane a couple of times but as soon as you turn it will drop back down and is not able to get on plane again.
no gray fuel lines
filter is good
carbs have been rebuilt
jet pump has been gone through and is in good condition
compression is good
spark is good
runs on both cylinders
timing has been checked
jets have been messed around with and don't make a difference
anyone have any ideas I am running out
engine is currently out of the ski for a crank case leak down test
no gray fuel lines
filter is good
compression is good
spark is good
