Theseadood
I recently just picked up my first jet ski, a 1994 Seadoo XP. When I picked it up the owner had it hooked up to a hose and it fired right up and ran through its range without issue. Mechanic brother along for advice. Wanted a water test but jumped on it anyways for $1300 with trailer. Just put it into the water yesterday for a test ride after filling with fresh 91 non oxy, put it into the water and it barely started after 10-12 cranks. Once started, almost no throttle response like it was starving for air. Minute later, started to open up and reach higher rpm, seemed alright. Slowed it back down, and as I was pulling back into shore it started to almost die on me, some white smoke coming from the back, although I had never turned my head around and looked for it until then. I’m assuming dirty carbs/old fuel or oil, dirty fuel lines. There was a bunch of mold under the front compartment after I checked around, if it sat... moisture...carbs... any help at all is appreciated! Willing and determined to take the carbs off and clean/rebuild them, just don’t want to take them off and go looking for a fish that ain’t there. Thanks!
