Block off...
Hey Ryan...
I just installed one on mine...anyway, the liine with inline filter goes to oil pump, thats the line you'll remove. Theres a 3/8ish spigot under carbs and exhaust manifold. Those are lines you'll continue to use from the oil resivoir, Heard you can connect those 2 lines , and do away w/ resivoir, but ???,
With the blockoff plate, you'll get a plate, 2 little rubber caps, those are for the brass fittings on intake plate, and 1 big cap for underneath the resivoir,
Totally remove the pump assy, you'll have to remove the plate carbs attached to, has 6/8 allen bolts, then remove nut on inside to terminate the inner gear. Check o-ring B-4 reinstalling of plate....alright, good luck
